DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Converting DWF files to DWG files
10 REPLIES 10
Message 1 of 11
MichaelHairfield8096
48737 Views, 10 Replies
Is there any way to convert DWF files to DWG files?
Mike Hairfield
10 REPLIES 10
Message 2 of 11
There is a firm out there selling a converter: I understand their support leaves a lot to be desired. Try a Google search and see if they are still around.
Have you tried just attaching a DWF inside a DWG? You just need a relatively recent version of AutoCAD or LT.
Message 3 of 11
I'm using AutoCAD 2012.
How do I attach a DWF file to a DWG file?
Mike
Message 4 of 11
In AutoCAD 2012, use DWFATTACH command.
Message 5 of 11
OK, I did that and it inserted the DWF file in to my AutoCAD drawing but everything is on "Layer 0".
I guess I should be glad that I can insert the DWF drawing, is there anyway to import the layers?
Mike
Message 6 of 11
Look up and use DWFLAYERS or ULAYERS commands.
Message 7 of 11
in reply to: MichaelHairfield8096
How do you convert a dwfx to a dwg? (I'm working with 2007)
Message 8 of 11
pendean
There are some 3rd party programs you can buy that promise to do so: use your favorite Internet Search Engine to find them.
Message 9 of 11
I know there is a DWF TO DWG converter, you can find it at www.Autodwg.com
They have other converters as well.
Message 10 of 11
Convert DWF to DWG https://youtu.be/rRteqPC9GDk
Message 11 of 11
A roundabout way that I have discovered for converting it, depending on how the dwf file was created (if it is only an image type file, then it wouldn't work), is to insert the dwf (have the dwf snap turned on) and then pdf the file and then you can insert the pdf and import the pdf as objects.
