Is there any way to convert DWF files to DWG files?
Mike Hairfield
There is a firm out there selling a converter: I understand their support leaves a lot to be desired. Try a Google search and see if they are still around.
Have you tried just attaching a DWF inside a DWG? You just need a relatively recent version of AutoCAD or LT.
I'm using AutoCAD 2012.
How do I attach a DWF file to a DWG file?
Mike
OK, I did that and it inserted the DWF file in to my AutoCAD drawing but everything is on "Layer 0".
I guess I should be glad that I can insert the DWF drawing, is there anyway to import the layers?
Mike
A roundabout way that I have discovered for converting it, depending on how the dwf file was created (if it is only an image type file, then it wouldn't work), is to insert the dwf (have the dwf snap turned on) and then pdf the file and then you can insert the pdf and import the pdf as objects.
