Solved by ukdxb012. Go to Solution.
Open Trueview 2015 and select the 3rd icon from the top left (next to open after the application button). If you hover over the icon it will say DWG Convert. Dont open the drawing first, go through DWG Convert.
Select that and you will get a dialog (Above) where you can load the DWG you want to convert and apply a conversion to it. Alternatively you can setup your own conversion.
Duncan
