I tried to convert from 2010 to 2007.
I am receiving the same error.
The drawing is saved on my desktop.
Is there a fix?
Tonia
Has anyone come up with a solution for this yet?
I use the 32-bit version of DWG TrueView on my computer and I can convert a file no problem.
I use the 64-bit version on a colleagues computer and get the error message that the file could not be saved due to a sharing violation or disk write problem.
Any help would be appreciated.
-Cindy
I don't know how but i managed to solve this problem (it occured to me too).
In the window "DWG Convert" double-click on "convert to 2007 (in-place)", or in your case the 2004 line. A new window opens. Change File Format in the dropdown list to DWG trueview 2007/ Autocad 2007 drawing format. Now try again to convert your file, it worked for me.
Tom
Tompax's solution (above) didn't work for me, but it gave me the hint to figure a solution that DID work.
double-click on the "convert to [2004][2007][2010] (in place)" ...just as Tompax says.
under "Conversion package type" you have a list of choices. i chose "Zip" (rather than "in-place"). i also checked the
"check and fix errors" box on the right -- but i dont think that was it.
in any case, the new Zip file worked just fine. file opens up now.
I found the following solution,
go to conversion setup, modify and change the file folder to the same place where is the file to convert.
I hope that help you.
Regards.
