When batch plotting to pdf with TrueView 2011, I am getting an error. Cannot find or create the font "ArialMT". Any angular dimension with degrees symbols and radius or diameter dimensions with the diameter symbols are not displayed in the pdf file. The just show up as series of round dots. Please advise with ideas. Thanks.
Add the Font to the Font Folder for TrueView 2011 found at Program Files/Autodesk/ DWG Trueview 2011/Fonts perhaps?
Or similar path.
Though that is a TrueType and should be picked up by the Support File Search File if the Windows Font file is listed in Options, Files Tab.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Post a screen shot of those paths in Options.
I want to see that we are talking about the same thing.
Nothing Attached
