DWG TrueView
Active Contributor
tojonas
Message 1 of 9 (3,598 Views)
API for DWG TrueView
3598 Views, 8 Replies
04-03-2006 01:39 PM
Can I use any API to control DWG TrueView? I read that the API has been disabled, is this still correct?
The following is a quote from Scott Sheppard:
"No. Autodesk DWG TrueView (and the DWG viewer that ships with Autodesk DWF
Composer) is not supported for automation. "
(http://discussion.autodesk.com/thread.jspa?threadID=399590)
What I want to do is automate the publish process from DWG files to DWF files. (It needs to run as a batch job without any UI interaction)
Thanks in advance!
/Jonas Nilsson
*Scott Sheppard [Autodesk]
Message 2 of 9 (3,598 Views)
Re: API for DWG TrueView
04-03-2006 04:37 PM in reply to: tojonas
The official Autodesk position is that DWG TrueView has not been designed
nor tested for use as an ActiveX Control; however, based on its
architecture, some things just happen to work. I got this sample from a
fellow employee:
https://projectpoint.buzzsaw.com/ConstructionManagement/public/testDWG.htm?public
So you are free to look at it as a sample. If it does not work perfectly for
you, please don't expect quick resolutions from Autodesk. This is provided
on an as-is basis - much like the only house I ever purchased in California.
wrote in message news:5130500@discussion.autodesk.com...
Thanks in advance!
/Jonas Nilsson
Active Contributor
tojonas
Message 3 of 9 (3,598 Views)
04-03-2006 07:17 PM in reply to: tojonas
Thanks Scott for the fast response!
/Jonas
Active Contributor
Anand Iyer (Autodesk)
Message 4 of 9 (3,598 Views)
04-11-2006 01:20 AM in reply to: tojonas
Attached is a JavaScript app written by some of our developers to use the APIs for DWG TrueView.
Active Contributor
tojonas
Message 5 of 9 (3,598 Views)
04-11-2006 06:22 AM in reply to: tojonas
Anand,
This looks great, thanks for sharing this.
/Jonas Nilsson
Message 6 of 9 (3,598 Views)
04-18-2006 07:02 AM in reply to: tojonas
I had the wrong version of the file on my site. It has been corrected.
This is the file that I got from one of the developers.
wrote in message news:5138717@discussion.autodesk.com...
Anand,
/Jonas Nilsson
Member
scalepage
Message 7 of 9 (3,598 Views)
12-15-2008 06:12 AM in reply to: tojonas
I am setting a website to support user-uploaded models and design files. one of the formats to be supported is DWG. however I can't get any API for that. can you share your API with me? or provide some guideline?
my email is michael.deng@scalepage.com
Thanks a lot.
Michael
Member
jean_pablo
Message 8 of 9 (2,229 Views)
02-21-2013 04:30 AM in reply to: scalepage
I also need this API, my email: jeancomp@gmail.com, thank.
Charles_Shade
Message 9 of 9 (2,225 Views)
02-21-2013 04:39 AM in reply to: jean_pablo
While you are waiting this nearly seven year old thread likely will not get any response from the previous parties.
You may want to post a new thread with your query if you do not get a response in a week or so.
Though that does not guarantee a satisfactory response either.
And some additional Google hits on your query:
https://www.google.com/search?num=100&hl=en&client=firefox-a&hs=g9B&rls=org.mozilla:en-US:smileysurprised:fficial&spe...
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
