• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Member
    Majd_Zoubi
    how to get geometry data from DWF file
    990 Views, 12 Replies
    02-24-2012 02:22 AM
    I'm trying to make new importer in SimLab Composer reads DWF file so I need object geomety data .
    I could not find any examples on how to extract object geometry data. is there any example helps me ? if not , would it possible to get small code shows how to get DWFModel and object geometry data from DWF File .
    regards
    Majd
    Please use plain text.
    Re: how to get geometry data from DWF file
    03-27-2012 07:56 AM in reply to: Majd_Zoubi
    You need to look at W3D samples. All 3D data is stored inside .w3d file which is inside .dwf file.
    Member
    Majd_Zoubi
    03-27-2012 01:19 PM in reply to: geotavros
    thanks for your reply,
    now i have get geometry data through BStreamFileToolKit parsing, now I'm trying to read node names for each node , the structure in ObjectDefinitionReader example is clear to traversing around nodes and reading names but i can't see how to match between objects and names in BStreamFileToolKit parsing.
    regards,
    Majd
    Employee
    04-05-2012 10:59 PM in reply to: Majd_Zoubi
    Thank you for your question.
    You use the ObjectDefinitionReader to get the node’s name and node’s id; the node id is used to match the geometry object, which is the tag id (TK_Tag).
    Please let us know if you have any further questions.
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Member
    Majd_Zoubi
    04-08-2012 05:11 AM in reply to: SilviaCao
    thank you for your reply
    can you show me small code example .
    Employee
    04-09-2012 07:01 PM in reply to: Majd_Zoubi
    We don’t have the sample yet; you will need to write the code.
    Please let us know if you have any question.
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    02-10-2013 07:13 AM in reply to: SilviaCao
    Using ReadContentDefinition sample I got all DWFInstance objects. Using DWFInstance::getNodeID() I got ID of each instance. The IDs are: 1, 2, 3, 4 for my sample file.
    When parsing 3D stream using SimpleW3DStreamProcessor sample I get TKE_Tag opcode and handle it using TK_Tag's subclass TkTagHandler. In TkTagHandler::Execute() I increase the counter.
    In my sample file I get like 12 TKE_Tag opcodes.
    I want to get the extended attributes of TK_Shell entities. And can't find a way to match the ID obtained from DWFInstance::getNodeID() with TK_Shell entity. You say I need to use the count of TK_Tag entities, but when do I need to start counting them? Do I need to count them from the start of 3D stream parsing or from the TK_Open_Segment?
    Member
    02-13-2013 07:45 AM in reply to: Majd_Zoubi
    Silvia is there a way to add more properties using the ObjectDefinition that you commented above?
    Emanuel Ceballos
    ENGworks - Software Developer
    Employee
    02-15-2013 07:23 PM in reply to: geotavros
    Count the TK_Tag; and the current segment (TK_Open_Segment) which contains the TK_Tag will be map to the DWGInstance by the node id and tag id.
    Silvia
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Employee
    02-15-2013 07:31 PM in reply to: emanuel.ceballos
    Yes, we can add more properties to the ObjectDefinition:
    1. Read the DWF and the ObjectDefinition (please refer to the toolkit sample ObjectDefinitionReader);
    2. Add more properties to the ObjectDefinition;
    3. Save the DWF file and the ObjectDefinition.
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
