I'm trying to make new importer in SimLab Composer reads DWF file so I need object geomety data .
I could not find any examples on how to extract object geometry data. is there any example helps me ? if not , would it possible to get small code shows how to get DWFModel and object geometry data from DWF File .
regards
Majd
thanks for your reply,
now i have get geometry data through BStreamFileToolKit parsing, now I'm trying to read node names for each node , the structure in ObjectDefinitionReader example is clear to traversing around nodes and reading names but i can't see how to match between objects and names in BStreamFileToolKit parsing.
regards,
Majd
Thank you for your question.
You use the ObjectDefinitionReader to get the nodeās name and nodeās id; the node id is used to match the geometry object, which is the tag id (TK_Tag).
Please let us know if you have any further questions.
We donāt have the sample yet; you will need to write the code.
Please let us know if you have any question.
Using ReadContentDefinition sample I got all DWFInstance objects. Using DWFInstance::getNodeID() I got ID of each instance. The IDs are: 1, 2, 3, 4 for my sample file.
When parsing 3D stream using SimpleW3DStreamProcessor sample I get TKE_Tag opcode and handle it using TK_Tag's subclass TkTagHandler. In TkTagHandler::Execute() I increase the counter.
In my sample file I get like 12 TKE_Tag opcodes.
I want to get the extended attributes of TK_Shell entities. And can't find a way to match the ID obtained from DWFInstance::getNodeID() with TK_Shell entity. You say I need to use the count of TK_Tag entities, but when do I need to start counting them? Do I need to count them from the start of 3D stream parsing or from the TK_Open_Segment?
Silvia is there a way to add more properties using the ObjectDefinition that you commented above?
Count the TK_Tag; and the current segment (TK_Open_Segment) which contains the TK_Tag will be map to the DWGInstance by the node id and tag id.
Silvia
Yes, we can add more properties to the ObjectDefinition:
Hi Silvia, thanks very much for your answer. I've managed to read the ObjectDefinition, this returns a list of DWFDefinedObjectInstance and I'm adding new properties to these Instances using pInst->addProperty( DWFCORE_ALLOC_OBJECT(DWFProperty(L"my_name", L"my_value", L"my_category")), true );
What I can't find is a way to save the modifications to the DWF and the ObjectDefinition. What's the correct way to do this?
Thanks.
You can save the new object definition resource by DWFObjectDefinitionResource::serializeXML; here is a code snapshot:
DWFPointer<DWFBufferOutputStream> apOutputStream( DWFCORE_ALLOC_OBJECT(DWFBufferOutputStream(_DWFTK_OBJECT_DEFINITION_RESOURCE_INITIAL_BUFFER_BYTES)), false );
DWFUUID oUUID;
DWFPointer<DWFXMLSerializer> apSerializer( DWFCORE_ALLOC_OBJECT(DWFXMLSerializer(oUUID)), false );
apSerializer->attach( apOutputStream );
objectdefinitionresource->serializeXML( apSerializer, DWFPackageWriter::eObjectDefinition );
apSerializer->detach();
The code is to create a new stream of the object definition resource; then you can create a new DWFObjectDefinitionResource and attach the new stream.
Thank you very much Silvia. I will try it and let you know.
Hello Silvia,
I would like to start the discussion on "how to get geometry data from DWF file" again. From the earlier discussion I understand that I have to add a counter during reading the segment and shell. Please let me know whether my understanding is correct.
I did following changes in my implementation of TK_Open_Segment and TK_Shell handler classes.
1. I created one static counter and initialized it with 0 (since the tags are seen to be initialized from 1 and indices been starting with 0). Please let me know whether this is correct.
2. I incremented the counter in Execute() implementation inside OpenSegment and Shell opcode handlers.
With these changes i assumed that the counter value in shell handler is the same as that for the node id for the corresponding object (DWFObject).
But I got results that did not match the DWFInstance id with the counter.
Please let me know if I am doing anything wrong. I have attached the sample file which is written using the sample program 3DPublish (sample3DPublish.dwf) and the modified SimpleW3DStreamProcessor.cpp which implements the counter mechanism.
Thank you,
Anup
Tech Lead
Prototech Solutions
