DWF
dwfx definePageLayout parameters
1 REPLY 1
janderssen
319 Views, 1 Reply
I would like to know what is the safest and most reliable way to populate the definePageLayout matrix, and width, height and scale parameters.
Example code to show this would be very much appreciated.
Thanx in advance.
Cheers
Jason
1 REPLY 1
herbert.he
in reply to: janderssen
Thank you for your question.
You can find the sample "XPSTest" from DWF Toolkit package that shows how to use the definePageLayout:
WT_Matrix2D oTransform;
{color:#999999}//
// This transform must match the one on the graphics resource exactly
//{color}
double fScale = 0.0016792611251049536;
oTransform(0,0) = fScale;
oTransform(1,1) = fScale;
oTransform(2,0) = 4.3706968933669188;
oTransform(2,1) = 6.1601595298068847;
{color:#999999}//{color}
{color:#999999}// The heigh and width values must match those of the section's paper
// the scale is a factor to scale the units given in the page size to inches...
// so if the paper size is in mm, it should be 0.03937
{color}{color:#999999}//{color}
ERR_CHECK( pxFile->definePageLayout(oTransform, 11, 8.5, 1) );
Please let me know if you have any follow-on questions.
-Herbert
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
”Boost
”Tips
”Services
