One of the sample applications that comes with the
DWF Toolkit developer SDK is called MergeFiles. The sample application
allows you to drag-and-drop files to be merged into one single DWF. The
sample application is intended for developers and is provided as C++ code, which
isn't what you want.
Luckily, Jeff Klug posted a built version of the
sample so you don't need to be a developer to use the MergeFiles program.
Here is a CC of Jeff's earlier post on the MergeFiles example
application:
> I've just posted the updated MergeFiles sample app
to the
> autodesk.autocad.customer-files area under the
subject "DWFs to DWF6 /
> Merging DWFs". This
allows you not only to convert old DWFs to DWF6, but
allows you to aggregate DWFs together into one DWF6 package. Give it a
try.
> Good luck.
-Brian
Mathews
href="mailto:brian.mathews@autodesk.com">brian.mathews@autodesk.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Just curious if anyone has a solution for
this. I don't own Volo View, so I don't know if that adds the
functionality I am looking for. I have seperate dwf files and want to
combine them into one file. In PDF you just drag and drop, I am hoping
there is a simular function.
