The 7.7 toolkit sample crashes on line:
DWFContent* pContent = pContentManager->getContent();
The file I'm using is the default one 3DPublishOut.dwf. I also tried custom files.
Windows 7 x64. I've downloaded DWFToolkit-7.7-bin-win32.zip and used Visual Studion 2008 to build the sample.
BTW, when I open the sample project I get a bunch of errors of loading projects DWF Core Library, DWFToolkit etc. Thus those projects are marked with grey color. Nevertheless the sample builds fine. Just crashes.
The problem was in default project configurations. Specifically wrong DLL versions were used for the sample. So after some time of struggling with it you can solve the problem and it doesn't crash.
