DWF
Q: DWF paper format?
2 REPLIES 2
pivari
299 Views, 2 Replies
Is it publish the DWF paper format?
Where can I find it?
Fabrizio
2 REPLIES 2
in reply to: pivari
You can download the DWF file toolkit from
href="http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=823771">http://usa.autodesk.com/a...
This has the spec in HTML and some sample code in C++. If you are not a
C++ kind of guy, this won't make too much sense. If you have AutoCAD, you can
change your plotting parameters so that it generates an ASCII DWF file. Once you
have an ASCII DWF file, you can use any text editor to look at it. You can get a
sense of what the commands are by doing that. You can see how colors are set,
lines are drawn, etc. It's kind of intuitive just by looking at the contents of
the DWF file.
Fabrizio
in reply to: pivari
Scott,
Thanks.
Fabrizio
”Boost
”Tips
”Services
