DWF
Problems plotting DWF's & printing to file (Converting to PDF)
1 REPLY 1
jkarbo
656 Views, 1 Reply
I am using Auto Desk Design Review 2012 viewing a DWF. I am trying to print to both a Canon ipf710 & ipf8300 (both non Post Script printers). When i send it to the printers its shrinks the image to an 8 1/2 x 11, when i try and print it to file (convert it to a PDF for easier printing) it either turns my file into one single 8 1/2 x 11 or makes it a binder of 30 8 1/2 by 11's cropping out sections of the drawing. I am positive i am printing it at full scale, correct paper size, and to the correct printers. I have tried 4 different PDF converters with all the same sizing issues. I downloaded a DWF to DWG converter and tried that but it threw all the colors on the drawing off, made line weight changes, and I experienced font substitution issues.
I called my Canon rep and his only solution was to either buy another P.S. printer or buy the full version of AutoCad cause it has a "HI driver?" He told me the DWF is not a standard graphic file and it is having a communication issue with my printer and that is why it is not printing correctly.
I have asked on multiple different forums across the web and i can not seem to find a solution to this problem. I have uninstalled/reinstalled Auto Desk, I have downloaded the "Hotfix/Service Pack" and none of this has worked.
If anyone has any information or possible solutions please let me know!!!
Thank you.
-J
1 REPLY 1
pendean
in reply to: jkarbo
Post your DWF and a screenshot of your print pop-up inside ADR.
”Boost
”Tips
”Services
