• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Member
    Tiands
    Migrating a RIP from DWF to DWFx
    165 Views, 1 Replies
    02-23-2011 09:05 AM
    I'm searching for documentation / samples regarding the following task:
    I have got a software rip for DWF files (and for lots of other file formats as well) using dwftoolkit 7.6
    I would like to add DWFx ripping capability to my rip.
    Somwhere I read things like "there's an kompatibily layer so that one can re-use 95% of code" when migrating from DWF to DWFx. But sadly I didn't find a starting point...
    I can not be the only one having this task?
    Please use plain text.
    Employee
    Re: Migrating a RIP from DWF to DWFx
    02-23-2011 01:34 PM in reply to: Tiands
    If you look at the DWF toolkit samples, specifically W2dtest and XPSTest, you'll see that the w2d output is done using a class factory. You can change to w2x by changing that code.
    As far as the package goes, you'll have to use the DWFXPackageWriter and/or DWFXPackagePublisher (SimpleXPS sample) instead of the DWF6PackageWriter.
    Hope this helps,
    Gyuri Ordody
    Principal Engineer
    Autodesk Labs
    Cheers,
    Gyuri Ordody
    Autodesk Labs
