• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Member
    Materials appear
    174 Views, 3 Replies
    11-19-2007 07:45 AM
    when I export a textured 3d model to dwf and open it in Design Review the faces appear completely white from certain angles (as if there is no texture applied). Is there something I need to do in AutoCad before I export to avoid or reduce this or can it be fixed within Design Review
    Many thanks
    John Q.
    Please use plain text.
    Member
    Re: Materials appear
    12-13-2007 03:45 AM in reply to: TripJs
    Bump
    Hi, anybody know if this is normal and do I just have to live with it or can I do anything to at least reduce the "washout" effect. It helps a litlle if I change the lights in ADR to "primary" but the model still appears white when you look directly at the faces (see attached pic)
    Anybody any comments / ideas?
    John Q.
    *V Joseph \(DWF Beta Manager\)
    02-28-2008 09:41 AM in reply to: TripJs
    I replied to this thread in the other discussion group.
    wrote in message news:5800104@discussion.autodesk.com...
    Bump
    John Q.
    Distinguished Contributor
    12-11-2009 05:31 AM in reply to: TripJs
    Which forum Joseph?
    I am having the same problem. Is it possible to set Primary Lights as a permenant setting (rather than having to set the lights to primary every time a DWF is opened) in Design Review 2010?
