DWF
lilshoob
Message 1 of 5 (48 Views)
Layers from 2004
48 Views, 4 Replies
09-12-2003 04:34 AM
I have the trial version of 2004 and when I publish
drawings to dwf and open them in the viewer, the
icon for showing the layers is grayed out. Is this
because it's a trial version?
*Sheppard, Scott
Message 2 of 5 (48 Views)
Re: Layers from 2004
09-12-2003 05:01 AM in reply to: lilshoob
No. I think it's because you are not exporting the
layers when you create the DWF. This is an option because some users choose NOT
to include the layer info, because they worry that a recipient will turn off
some of the layers and then build what they see. I think you can adjust your
publish settings to include the layer information.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
*Fritts, Mark
Message 3 of 5 (48 Views)
Re:
09-16-2003 07:46 AM in reply to: lilshoob
Here are the steps to including layers in your
DWF. Hope this helps:
  1. style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">Select
    Page Setup from the File menu
style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">
2.   In the Plotter Configuration dropdown, select DWF6 ePlot.pc3 from
the list.
style="mso-spacerun: yes">
3.   Select the Properties button.
This will bring you too the Plotter
Configuration Editor dialog.
style="MARGIN: 0in 0in 0pt; mso-list: l0 level1 lfo1; tab-stops: list .5in">    4.
Click on the Custom Properties folder in the tree view
5.   Click on the Custom Properties button that appears at the bottom
of the dialog
6.   This will bring you to theDWF6 ePlot Properties dialog.
7.   Check the box to Include layer information.
8.   You will be asked if you wish to save this setting to your PC3
Printer Configuration file.  Select
Ok.
face=Arial size=2>mark fritts
face=Arial size=2>Autodesk
the layers when you create the DWF. This is an option because some users
choose NOT to include the layer info, because they worry that a recipient will
turn off some of the layers and then build what they see. I think you can
adjust your publish settings to include the layer information.
I
drawings to dwf and
Is this
version?
*Murph
Message 4 of 5 (48 Views)
Re:
09-16-2003 11:09 PM in reply to: lilshoob
Thanks Mark, now what is the secret to creating the
named views and hyperlinks to work? I have named views and the hyperlinks
created in the dwg but the hyperlink is grayed out in the dwf (under
show) and the views do not show up on the view in the list just the
initial view.
Murph
from the list.
bottom of the dialog
Select Ok.
will turn off some of the layers and then build what they see. I think you
can adjust your publish settings to include the layer
information.
I
drawings to dwf and
out. Is this
version?
*Brown, Anne
Message 5 of 5 (48 Views)
Re:
09-17-2003 02:51 AM in reply to: lilshoob
Gentlemen!!! The HTML posting is so heavy the messages are not
readable in newsgroup reader software. !!! Showing what it looks
like and posting translation at the bottom.
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
Path: WebX
Newsgroups: autodesk.dwf
Subject: Re: Layers from 2004
Message-ID:
Date: Wed, 17 Sep 2003 07:09:47 -0700
References:
Lines: 190
X-Priority: 3
X-MSMail-Priority: Normal
X-Newsreader: Microsoft Outlook Express 6.00.2600.0000
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2600.0000
MIME-Version: 1.0
Content-Type: text/html;charset="iso-8859-1";
charset="ISO-8859-1"
Content-Transfer-Encoding: 8bit
to creating the
hyperlinks
(under
list just the
initial view.
Murph
layers in your
AR-SA">
DWF6 ePlot.pc3
from the list.
AR-SA">
the Plotter
appears at the
dialog.
setting to your PC3
Select Ok.
not exporting
some users
a recipient
see. I think you
information.
I
drawings to dwf and
layers is grayed
out. Is this
version?
Murph wrote:
> Thanks Mark, now what is the secret to creating the named views
> (under show) and the views do not show up on the view in the
> list just the initial view.
> Murph
> "Mark Fritts" wrote in
> message
> news:B00E5D31D999CDFCAA9F1458A2CD0FA9@in.WebX.maYIadrTaRb...
> 1. Select Page Setup from the File menu
> select DWF6 ePlot.pc3 from the list.
> 3. Select the Properties button. This will
> bring you too the Plotter Configuration Editor
> dialog.
> 4. Click on the Custom Properties folder in the
> tree view
> appears at the bottom of the dialog
> Properties dialog.
> setting to your PC3 Printer Configuration file.
> Select Ok.
> mark fritts
> Autodesk
> "Scott Sheppard"
> wrote in
> message
> news:B2619940D42E9D2983DF26F0B82F33BC@in.WebX.maYIadrTaRb...
> exporting the layers when you create the
> information.
> "lilshoob" wrote in
> message
> news:f189d96.-1@WebX.maYIadrTaRb...
> and when I publish
> the viewer, the
> grayed out. Is this
