• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Valued Contributor
    Large print spool files when printing scanned dwf
    297 Views, 4 Replies
    10-12-2011 08:53 AM
    We have some dwf files that were created from old paper drawings scanned to TIFF then printed to DWF. When these files are sent to a printer the print spool size is large, for example an A-Sized drawing of a simple cup is 21 MB. While a very similar print that was converted from an IDW is 364KB. But the file size of the two DWFs is realtively close, 34KB and 67KB respectively.
    This is slowing down traffic on our WAN.
    Any thoughts?
    Please use plain text.
    Employee
    Re: Large print spool files when printing scanned dwf
    10-13-2011 02:11 AM in reply to: MarkMazour
    There are several ways to reduce spool file size.
    1. Select small paper size
    2. Reduce print dpi
    3. Print to gray/black and white instead of color
    Thank you
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
    Valued Contributor
    10-13-2011 05:51 AM in reply to: wube
    1. Select small paper size - The prints used for testing are A-Size
    2. Reduce print dpi - I will try this
    3. Print to gray/black and white instead of color - The prints used for testing are black and white
    I guess I was hoping to hear of some file compression or cleanup suggestions.
    pendean
    10-13-2011 06:18 AM in reply to: MarkMazour
    Nature of what you are printing: no fix other than what is suggested. A printer with higher speed and significant built-in RAM and/or HD can take the load away from your PC too.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    10-19-2011 05:56 AM in reply to: pendean
    Anybody know why it is larger? If I convert this file to a jpg the file size increases to 85k from 34k and when sent it to the printer the spool file is down to 3.4mb from the 21mb.
