DWF
Member
PedroUdjat
Message 1 of 2 (667 Views)
Incorrect coordinate geometry in dwfx
667 Views, 1 Replies
08-06-2012 10:51 AM
Hi everyone,
I have a problem extracting dwg coordinate geometry from a dwfx file.
Using as an example the W2Dtest sample and the Read2DDWFxFile.cpp file, I get all the Whip coordinates.
For example:
2147467780, 8657
2147468114, 9319
I read in this topic that the coordinates appear correct:
http://forums.autodesk.com/t5/DWF/DWF-geometry-data/td-p/1887709/page/2
But when I  try to convert this coordinates to the original AutoCAD DWG coordinates, using first:
WT_Matrix xform3d( pGraphicsRes->transform() );
DWFToolkit::smileyvery-happy:WFPaper *pPaper( pEPlotSxn->paper() );
WT_Matrix2D xform;
xform(0,0) = xform3d(0,0);
xform(1,0) = xform3d(1,0);
xform(0,1) = xform3d(0,1);
xform(1,1) = xform3d(1,1);
xform(2,0) = xform3d(3,0);
xform(2,1) = xform3d(3,1);
XAMLFile->definePageLayout(xform, pPaper->width(), pPaper->height(),
pPaper->units() == DWFToolkit::smileyvery-happy:WFPaper::eMillimeters ? .03937 : 1.0 );
and then for each point:
WT_Point3D correctCoord = units.transform_from_DWF_to_application(newPoint);
i get coordinates like this:
2142.55, 1011.14
2143.25, 1012.54
where I should be getting coordinates like this:
4543646.5803, 9.195
4545674.8390, 8.498
Any ideia what i'm doing wrong? Am I missing something? Any help is appreciated.
Pedro Cruz
Member
PedroUdjat
Message 2 of 2 (659 Views)
Re: Incorrect coordinate geometry in dwfx
08-10-2012 03:09 AM in reply to: PedroUdjat
Anyone?
I noticed that the the matrix that I get from WT_Units:
WT_Matrix original = units.application_to_dwf_transform();
have some correct values, and some other strange values like 2,89e-14. Is this normal? I could alter the values in the transformation matrix but I don't think that is the correct approach.
And i should be using units.transform_from_DWF_to_application(), not units.application_to_dwf_transform(), because I want the original DWG coordinates, but the output coordinates makes even less sense.
Any ideas? I'm really at a loss here.
Pedro Cruz.
You are not logged in.
Ask the Community
