• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    How to read drawable objects from 2D DWF file?
    845 Views, 3 Replies
    04-24-2012 08:19 AM
    I've used this sample code to read a 2D DWF file. I want to get Lines, Polylines, Text and other drawable objects from the DWF file but all I get is this list of object's types:
    Spoiler
    DWF_Header_ID
    Creator_ID
    Creation_Time_ID
    Modification_Time_ID
    Source_Filename_ID
    Source_Creation_Time_ID
    Source_Modification_Time_ID
    Units_ID
    Title_ID
    Embed_ID
    Named_View_ID
    Named_View_ID
    View_ID
    Plot_Info_ID
    Optimized_For_Plot_ID
    Color_ID
    Layer_ID
    Font_Extension_ID
    Font_ID
     How can I get those drawable entities?
    I'm using OS X Lion and XCode 4.3.2.
    I've attached my source code and DWF file
    For reading DWFx files I used this code and it works. It reads polyline and text objects.
    Edited by
    Discussion_Admin
    Please use plain text.
    Workaround
    04-25-2012 07:05 AM in reply to: geotavros
    I've found the problem. while loop breaks because of
    WT_Result::Unsupported_DWF_Opcode is returned from
    process_next_object(). This example code doesn't break the loop on this error, and continues until some other error happens:
    do {
                r = inputStream.process_next_object();
                const WT_Object* obj = inputStream.current_object();
                if (obj)
                    printObjectType(obj->object_id());
                // we can serialize the obj to another file
                cout << r << endl;
    } while (r == WT_Result::Success || r == WT_Result::Unsupported_DWF_Opcode);
    New Member
    Re: How to read drawable objects from 2D DWF file?
    09-19-2012 03:31 PM in reply to: geotavros
    I'm working on a small project trying to do the same and was wondering if you could point me to the example you used. I didn't see any files attached to the message?
    Hoping you can help. Thanks.
    09-21-2012 02:19 AM in reply to: edporras
    I don't know where is it gone. Or if the link was removed. There is an example of 2D reading on this forum, find it. it is very helpful
