DWF
New Member
Message 1 of 1 (438 Views)
How to extract URL from DWF file especially non-english URL?
438 Views, 0 Replies
01-28-2013 12:00 AM
Hello,expers
    I am tring to extract all the URL information from specified DWF file now.However,when trying to process the DWF file with chinese characters,it always fail.I have pasted my code fragment as following:
DwfW2DHandler::smileyvery-happy:wfW2DHandler( DWFInputStream& rStream, bool bHtmlOutput)
: rW2DStream( rStream )
, m_iUrlIndex( 0 )
//setup the URL action here to catch it.
set_url_action( HandleURL );
set_text_action( HandleText );
set_file_mode( WT_File::File_Read );
set_stream_user_data( this );
open();
DwfW2DHandler::~DwfW2DHandler()
close();
//some basic required function for derived class to be implemented
WT_Result DwfW2DHandler::smileytongue:rocess_stream_close(void)
return WT_Result::smileyfrustrated:uccess;
WT_Result DwfW2DHandler::smileytongue:rocess_stream_end_seek()
WT_Result DwfW2DHandler::smileytongue:rocess_stream_open(void)
//heuristics().set_allow_binary_data(true);
//heuristics().set_allow_data_compression(true);
nBytesAvailable = rW2DStream.available();
//wcout<< L"DwfW2DHandler::smileytongue:rocess_stream_open nBytesAvailable = "<<nBytesAvailable<<endl;
WT_Result DwfW2DHandler::smileytongue:rocess_stream_read ( int desired_bytes, int& bytes_read, void* buffer )
WT_Result result = WT_Result::smileyfrustrated:uccess;
//wcout << L"Enter DwfW2DHandler::smileytongue:rocess_stream_read desired_bytes = "<<desired_bytes<<endl;
try
bytes_read = ( int )rW2DStream.read( buffer, desired_bytes );
catch (...)
result = WT_Result::Internal_Error;
//wcout << L"Exit DwfW2DHandler::smileytongue:rocess_stream_read bytes_read ="<<bytes_read<<L"result="<<result<<endl;
return result;
WT_Result DwfW2DHandler::smileytongue:rocess_stream_seek (int distance, int& amount_seeked)
try
amount_seeked = rW2DStream.seek( SEEK_CUR, distance );
catch (...)
return result;
WT_Result DwfW2DHandler::smileytongue:rocess_stream_tell (unsigned long *current_file_pointer_position)
*current_file_pointer_position = (int)(nBytesAvailable - rW2DStream.available());
WT_Result DwfW2DHandler::smileytongue:rocess_stream_write(int size, void const* buffer)
return WT_Result::Toolkit_Usage_Error;
WT_Result DwfW2DHandler::smileytongue:rocess()
//wcout << L"Enter DwfW2DHandler::smileytongue:rocess"<<endl;
while( WT_Result::smileyfrustrated:uccess == ( result = process_next_object() ) ||
WT_Result::Unsupported_DWF_Opcode == result )
//wcout << L"DwfW2DHandler::smileytongue:rocess process next object success"<<endl;
WT_Object const* pCurrentObj = current_object();
wcout << L"DwfW2DHandler::smileytongue:rocess id ="<<pCurrentObj->object_id()<<endl;
if ( ( pCurrentObj->object_id() == WT_Object::URL_ID ) ||
( pCurrentObj->object_id() == WT_Object::URL_List_ID ) )
//wcout << L"DwfW2DHandler::smileytongue:rocess URL List object found"<<endl;
if ( pCurrentObj->object_id() == WT_Object::Text_ID )
WT_String const & rTextString = ( ( WT_Text* )pCurrentObj )->string();
wchar_t* pTextString = WT_String::to_wchar( rTextString.length(), rTextString.unicode() );
pTextString = pTextString ? pTextString : L"NULL";
//wcout <<L"Text String ="<<pTextString<<endl;
return result;
WT_Result DwfW2DHandler::HandleURL( WT_URL& rUrl, WT_File& rFile )
//wcout << L"Enter DwfW2DHandler::HandleURL"<<endl;
DwfW2DHandler& rThisHandler = ( DwfW2DHandler& )rFile;
WT_URL_List urlList = rUrl.url();
WT_URL_Item* pUrlItem = NULL;
for ( ;( ( pUrlItem = urlList.url_item_from_index( rThisHandler.m_iUrlIndex ) ) != NULL ); rThisHandler.m_iUrlIndex++ )
WT_String& rUrl = pUrlItem->address();
wchar_t* pUrlString = WT_String::to_wchar( rUrl.length(), rUrl.unicode() );
//wcout <<L"Length="<<rUrl.length()<<endl;
wcout << L"[Machine-readable URL=" << pUrlString<<L"]"<<endl;
delete [] pUrlString;
//if friendly_name then append that otherwise put the address as URL text
if( pUrlItem->friendly_name() )
//wcout << L"friendly name exist"<<endl;
WT_String& rFriendlyNameString = pUrlItem->friendly_name();
wchar_t* pFriendlyName = WT_String::to_wchar( rFriendlyNameString.length(), rFriendlyNameString.unicode() );
//delete when you are done here
//wcout<<L"Length="<<rFriendlyNameString.length()<<endl;
wcout << L"[Human-readable URL=" << pFriendlyName<<L"]"<<endl;
delete[] pFriendlyName;
WT_Result DwfW2DHandler::HandleText( WT_Text& rText, WT_File& rFile )
//wcout << L"Enter DwfW2DHandler::HandleText"<<endl;
WT_String const & rTextString = rText.string();
//wcout <<L"pTextString="<<pTextString<<endl;
According to the testing result,program will simply exit when calling HandleText if the text is chinese. Anyway, the code is long and boring, thanks for reading and help.
best regards
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
