• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Active Member
    1810msa
    How can I parse DWFX Files using Dwf toolkit 7.6
    1045 Views, 7 Replies
    03-08-2011 02:19 AM
    Hi all,
    I want an example showing how to parse DWFX files using Dwf toolkit 7.6.
    The parsing I need is using process_next_object(), and object processing by my callback.
    Can anyone help me pleeeeeeeeease ?
    Hmeidi.
    Please use plain text.
    Active Member
    1810msa
    Re: How can I parse DWFX Files using Dwf toolkit 7.6
    03-09-2011 08:08 AM in reply to: 1810msa
    No replies ??????????
    I can hear my echo.
    Employee
    03-13-2011 08:08 PM in reply to: 1810msa
    Thank you for your question.
    Please refer the DWF Toolkit samples “W2dTest” and “XPSTest” to read/write a DWFx file.
    1. Download the DWF Toolkit;
    2. The samples “W2dTest” and “XPSTest” are under \samples\DWFToolkit
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    Active Member
    1810msa
    08-09-2011 08:00 AM in reply to: SilviaCao
    Thanks Silvia,
    I tried to use the two samples “W2dTest” and “XPSTest", but non of two samples succeeded to load dwfx files.
    I passes dwfx file path to read_test() function that exists in the two samples and I got the following results:
    W2dTest Sample:
    the following line caused a crash:
    pXamlFileDescriptor->open();
    XPSTest Sample:
    the function process_next_object() returned WT_Result::Internal_Error
    Thanks for your help,
    Hmeidi
    Employee
    08-09-2011 11:03 PM in reply to: 1810msa
    I will answer your questions in order.
    1. W2dTest, please check the sample calls “write_test” before “read_test”.
    2.      Open this sample folder, there is a file “W2DTest.ini” configures the sample to read/write the dwf/dwfx file.
    2. XPSTest, this sample is to write a dwfx file; the “read_test” and “skip_test” was corrupt, please ignore the two functions.
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    Active Member
    1810msa
    08-10-2011 07:13 AM in reply to: SilviaCao
    Thanks Silvia,
    It seems that w2dtest reads w2x and xaml files but I need to read dwfx package,
    Is there a sample that reads dwfx files directly ?
    Thanks again,
    Hmeidi
    Employee
    08-11-2011 02:43 AM in reply to: 1810msa
    You can refer to the sample code Read2DDWFxFile.cpp.
    Silvia Cao
    SW Engineer
    PSEB-GE- ACRD PSEB
    New Member
    02-10-2013 01:31 PM in reply to: 1810msa
    Do you have any examples of parsing 3D content?
    Thank you.
