• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    *Raghavendra Shetty
    DWG to DWF Conversion with Block Info
    64 Views, 6 Replies
    06-15-2006 03:03 AM
    Hi Scott,
    I want to Convert  DWG files to DWF with Block
    information......
    is there any converter to do the above without
    Autocad
    (i got DWG to DWF converter without block info
    which wll not serve my purpose...)
    any help would be appreciated......
    regards,
    Raghavendra Shetty
    Software Engineer
    r
    color=#0000a0>e
    achwell
    Reachwell Software Services
    Ltd
    #15 , Basappa Road
    Shantinagar
    Bangalore - 560 027
    Cell : +91 93419 88994
    Tel  : +91 80 22230382
    Fax : +91 80
    22235962
    Please use plain text.
    *Scott Sheppard [Autodesk]
    Re: DWG to DWF Conversion with Block Info
    06-15-2006 10:54 AM in reply to: *Raghavendra Shetty
    The free Autodesk DWG TrueView will convert a DWG
    to DWF with object properties created from block attributes.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Hi Scott,
    Block information......
    Autocad
    regards,
    Raghavendra Shetty
    Software Engineer
    r
    color=#0000a0>e
    achwell
    Ltd
    #15 , Basappa Road
    Shantinagar
    Bangalore - 560 027
    Tel  : +91 80
    22230382
    Fax : +91 80
    22235962
    *Raghavendra Shetty
    06-16-2006 05:43 AM in reply to: *Raghavendra Shetty
    Hi Scott,
    Thanks for the help...........
    regards,
    Raghavendra Shetty
    Software Engineer
    r
    color=#0000a0>e
    achwell
    Ltd
    #15 , Basappa Road
    Shantinagar
    Bangalore - 560 027
    Fax : +91 80
    22235962
    Hi Scott,
    Autocad
    any help would be
    appreciated......
    regards,
    Raghavendra
    Shetty
    Software Engineer
    r
    color=#0000a0>e
    achwell
    Ltd
    #15 , Basappa Road
    Shantinagar
    Bangalore - 560 027
    Tel  : +91 80
    22230382
    Fax : +91 80
    22235962
    Member
    06-28-2006 01:52 AM in reply to: *Raghavendra Shetty
    Picking up on this thread... I also want to publish a DWF including block attributes (properties). I have followed all the stated instructions and still am unsuccessful.
    I use the publish command (Autocad2007 & trueview) and follow the instructions to change the page setup to 3D DWF, i then select from publish options to include blocks and i create a template file. I then publish and the object is outputted to my DWF viewer but no block information is available despite it being in the template.
    I seem to have tried every combination without success.. Please help
    Regards, Stephan Jones
    06-28-2006 08:19 PM in reply to: *Raghavendra Shetty
    From what I can tell, the publish options for allowing block properties
    applies to 2D only.
    wrote in message news:5221163@discussion.autodesk.com...
    template.
    Member
    06-30-2006 01:27 AM in reply to: *Raghavendra Shetty
    Scott, can you find out definitively please whether it is the case, and if it is are Autodesk planning to do anything about it in the future, also does this apply to exports from ALL other Autodesk products ie Revit/Inventor/ADT etc?
    06-30-2006 09:52 AM in reply to: *Raghavendra Shetty
    I will check around and post a reply.
    wrote in message news:5223875@discussion.autodesk.com...
    etc?
