• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Active Member
    pratap.thorat
    DWFWriter SDK.
    980 Views, 8 Replies
    09-07-2010 09:59 PM
       Is there any SDK available for an DWFWriter?
       please, provide the link to download.
    Thanks.
    Pratap.
    Please use plain text.
    Employee
    Re: DWFWriter SDK.
    09-07-2010 10:42 PM in reply to: pratap.thorat
    Hi Pratap,
    I have confirmed with developer that we don't have any SDK for DWF Writer.
    Could you please tell me what you will use that for so that our developers can provide any other help?
    -Dicky
    Dicky Shu
    SQA Engineer
    Autodesk DWF Writer Customer Support
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Active Member
    pratap.thorat
    Re: DWFWriter SDK.
    09-07-2010 11:34 PM in reply to: pratap.thorat
       Thanks for the information.
       I want the SDK or help , because I want to generate the 3D DWF files, from other file formats, programaticaly using
       DWFWriter.
    pratap.
    Employee
    Re: DWFWriter SDK.
    09-08-2010 12:09 AM in reply to: pratap.thorat
    Glad to get your reply quickly.
    Are you using 32bit or 64bit platform?
    You can generate 3D DWF files by DWF Writer 32bit, but can not do it by DWF Writer 64bit, because 64bit DWF Writer only support 2D for now.
    Please let me know if you have further question.
    -Dicky
    Dicky Shu
    SQA Engineer
    Autodesk DWF Writer Customer Support\
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Active Member
    pratap.thorat
    Re: DWFWriter SDK.
    09-08-2010 01:19 AM in reply to: dickyshu
       I am using 32bit platform.Is ther any API or some other way present , to generate 3D DWF files programaticaly.
    Pratap.
    Employee
    Re: DWFWriter SDK.
    09-08-2010 01:57 AM in reply to: pratap.thorat
    I have forwarded your question to our developer, he will response you later.
    -Dicky
    Dicky Shu
    SQA Engineer
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Employee
    Re: DWFWriter SDK.
    09-09-2010 05:11 AM in reply to: pratap.thorat
    Hi Pratap
    I would like to know whether you are satisfied with follow steps to print your files to 3D DWF.
    1. Install DWF Writer 32 bits.
    2. Create DC with DWF Writer printer.
    3. Draw your files on the created DC.
    4. Finally the 3D DWF will be output well.
    Tank
    SW Engineer
    PSEB-GE-ACRD-CPG
    Autodesk, Inc.
    Active Member
    pratap.thorat
    Re: DWFWriter SDK.
    09-09-2010 11:21 PM in reply to: whtank
       Thanks for providing the information.
       I have installed the DWFWriter 32 bit version and able  to create "3D DWF" files manually.
       But I want to create the "3D DWF" files pragmatically.
       As you said that , Create DC(Device context). Can I do this using any API, if provided by DWFWriter.
       If I install the DWFWriter 32 bit version, then is there any .dll file present that, I can add as a reference and use
       functions pragmatically to write the " 3D DWF"  file.
      or Is there any other tool available, which I can use and create the "3D DWF" files pragmatically.
    Pratap.
    Employee
    Re: DWFWriter SDK.
    09-15-2010 08:24 PM in reply to: pratap.thorat
    You can create "3D DWF" through DWFToolkit.
    The latest's DWFToolkit is available at http://www.autodesk.com/dwftoolkit
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
    Autodesk, Inc.
