DWF
Active Member
pratap.thorat
Message 1 of 9 (1,139 Views)
DWFWriter SDK.
1139 Views, 8 Replies
09-07-2010 09:59 PM
   Is there any SDK available for an DWFWriter?
   please, provide the link to download.
Thanks.
Pratap.
Employee
dickyshu
Message 2 of 9 (1,137 Views)
Re: DWFWriter SDK.
09-07-2010 10:42 PM in reply to: pratap.thorat
Hi Pratap,
I have confirmed with developer that we don't have any SDK for DWF Writer.
Could you please tell me what you will use that for so that our developers can provide any other help?
-Dicky
Dicky Shu
SQA Engineer
Autodesk DWF Writer Customer Support
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
pratap.thorat
Message 3 of 9 (1,135 Views)
Re: DWFWriter SDK.
09-07-2010 11:34 PM in reply to: pratap.thorat
   Thanks for the information.
   I want the SDK or help , because I want to generate the 3D DWF files, from other file formats, programaticaly using
   DWFWriter.
pratap.
Employee
dickyshu
Message 4 of 9 (1,133 Views)
Re: DWFWriter SDK.
09-08-2010 12:09 AM in reply to: pratap.thorat
Glad to get your reply quickly.
Are you using 32bit or 64bit platform?
You can generate 3D DWF files by DWF Writer 32bit, but can not do it by DWF Writer 64bit, because 64bit DWF Writer only support 2D for now.
Please let me know if you have further question.
-Dicky
Dicky Shu
SQA Engineer
Autodesk DWF Writer Customer Support\
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Active Member
pratap.thorat
Message 5 of 9 (1,128 Views)
Re: DWFWriter SDK.
09-08-2010 01:19 AM in reply to: dickyshu
   I am using 32bit platform.Is ther any API or some other way present , to generate 3D DWF files programaticaly.
Pratap.
Employee
dickyshu
Message 6 of 9 (1,126 Views)
Re: DWFWriter SDK.
09-08-2010 01:57 AM in reply to: pratap.thorat
I have forwarded your question to our developer, he will response you later.
-Dicky
Dicky Shu
SQA Engineer
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Employee
whtank
Message 7 of 9 (1,112 Views)
Re: DWFWriter SDK.
09-09-2010 05:11 AM in reply to: pratap.thorat
Hi Pratap
I would like to know whether you are satisfied with follow steps to print your files to 3D DWF.
  1. Install DWF Writer 32 bits.
  2. Create DC with DWF Writer printer.
  3. Draw your files on the created DC.
  4. Finally the 3D DWF will be output well.
Tank
SW Engineer
PSEB-GE-ACRD-CPG
Active Member
pratap.thorat
Message 8 of 9 (1,092 Views)
Re: DWFWriter SDK.
09-09-2010 11:21 PM in reply to: whtank
   Thanks for providing the information.
   I have installed the DWFWriter 32 bit version and able  to create "3D DWF" files manually.
   But I want to create the "3D DWF" files pragmatically.
   As you said that , Create DC(Device context). Can I do this using any API, if provided by DWFWriter.
   If I install the DWFWriter 32 bit version, then is there any .dll file present that, I can add as a reference and use
   functions pragmatically to write the " 3D DWF"  file.
  or Is there any other tool available, which I can use and create the "3D DWF" files pragmatically.
Pratap.
Employee
wube
Message 9 of 9 (1,051 Views)
Re: DWFWriter SDK.
09-15-2010 08:24 PM in reply to: pratap.thorat
You can create "3D DWF" through DWFToolkit.
The latest's DWFToolkit is available at http://www.autodesk.com/dwftoolkit
Ben Wu
SW Engineer
PSEB-GE-ACRD
You are not logged in.
Ask the Community
