DWF
*Bornhaupt, Thomas
Message 21 of 25 (122 Views)
Re:
10-13-2003 04:55 AM in reply to: BrianPickles
Hi Jeffrey,
then please make an Update to the documentation.
Thomas
"Jeffrey Klug (Autodesk)" <jeffrey dot klug at autodesk dot com>
schrieb im Newsbeitrag
href="news:smileyvery-happy:C4A9DB0235B336B17D3364F2DBE119E@in.WebX.maYIadrTaRb">news:smileyvery-happy:C4A9DB0235B336B17D3364F2DBE119...
Dwf 6 files themselves must begin with (DWF
V06.00).
Internal whip vector streams should begin with
(W2D V06.00).
AEV could read this DWF with no problem. But the Header
information of this file is not correct!
(DWF V06.00)  has to be (W2D V06.00) look to the
Whip6 SDK Doku.
VoloView shows 2 errors:
1) DWF file is newer...
2) Error regenerating graphic....
if you change with HexEdit to (W2D V06.00) then the first
error is gone. But then AEV says: " unknown error"
Have you an Ascii-Version of this file.
regards
Thomas
I'm
using ADT3.3 +Raster design as a tool to archive old scanned drawings -
have a problem displaying DWF6 in AEV.
Image format is binary .tif, I
had no problems using old format .DWF - Now image displays lines &
text as 'hollow' instead of solid black. see attached dwf file. anyone
have any ideas ?
*Bornhaupt, Thomas
Message 22 of 25 (122 Views)
Re:
10-13-2003 05:05 AM in reply to: BrianPickles
*Autodesk\
Message 23 of 25 (122 Views)
Re:
10-13-2003 06:41 AM in reply to: BrianPickles
The documentation is accurate.  The Whip spec
refers to streams within the DWF 6 format, the dwf spec refers to the DWF 6
package (zip) format.  See the first paragraph in the "What's New" section
of the WhipSpec.chm document included with the Dwf toolkit
distribution.
You can use the DWF toolkit to create DWF files of
version 6 (and ostensibly beyond):  (DWF V06.00)
You can use the Whip toolkit (also included in the
DWF toolkit distribution) to create DWF files of "classic" versions such as
00.42 through 00.55:  (DWF V00.42) -> (DWF V00.55).  This is the
toolkit to which you're likely referring.
For version 6 and beyond, the Whip toolkit is used
to create Whip streams for use within the DWF package format.  These
streams should not be used as standalone files.  Opening them in the AEV
viewer may work most of the time, but this is not supported nor
recommended.
Hi Jeffrey,
documentation.
Thomas
href="news:smileyvery-happy:C4A9DB0235B336B17D3364F2DBE119E@in.WebX.maYIadrTaRb">news:smileyvery-happy:C4A9DB0235B336B17D3364F2DBE1...
V06.00).
(W2D V06.00).
Whip6 SDK Doku.
first error is gone. But then AEV says: " unknown error"
regards
Thomas
I'm
I had no problems using old format .DWF - Now image displays lines &
have any ideas ?
*Autodesk, Sriram Gopalakrishnan -
Message 24 of 25 (122 Views)
Re: DWF6 - display of .tif images
10-13-2003 08:36 AM in reply to: BrianPickles
I tried publishing this drawing from AutoCAD 2004 and the published dwf
displays correctly in AEV.
Active Member
Message 25 of 25 (122 Views)
Re:
10-13-2003 05:48 PM in reply to: BrianPickles
Hi all,
Sriram - Thanks for reassuring me that raster images display correctly in AEV for DWF6 from AutoCAD 2004.
It must be the DWF creator for 2002 has some glitch.
thanks to you all for your input. I may even install ADT 2004 before the new year at this rate.
till the next time.
Brian
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
