• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • DWF
    Active Member
    DWF6 - display of .tif images
    47 Views, 24 Replies
    10-10-2003 01:55 AM
    I'm using ADT3.3 +Raster design as a tool to archive old scanned drawings - have a problem displaying DWF6 in AEV.
    Image format is binary .tif, I had no problems using old format .DWF - Now image displays lines & text as 'hollow' instead of solid black. see attached dwf file. anyone have any ideas ?
    Please use plain text.
    *Bornhaupt, Thomas
    Re: DWF6 - display of .tif images
    10-10-2003 02:04 AM in reply to: BrianPickles
    There was no attachment.
    If it is an Ascii DWF then you can send it to
    href="mailto:Thomas@Bornhaupt.de">Thomas@Bornhaupt.de
    regards
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I'm
    *Saadallah, Dean
    Re:
    10-10-2003 02:09 AM in reply to: BrianPickles
    The attachment is there: are you accessing this through browser? I use OE,
    it shows up fine.
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com/lt
    *Capper, Robin
    Re:
    10-10-2003 07:22 AM in reply to: BrianPickles
    You aren't alone, I have this with tiffs in dwfs also.
    Robin Capper
    Email; robin.capper.design@xtra.co.nz or robin.capper@thewarehouse.co.nz
    "Dean Saadallah" wrote in message
    news:542053ABDD8037D2330128610A93847C@in.WebX.maYIadrTaRb...
    > it shows up fine.
    > Dean Saadallah
    *Bornhaupt, Thomas
    Re:
    10-10-2003 06:55 PM in reply to: BrianPickles
    Thats silly. I use OE6. I can see an attachment, but i could not extract it.
    All buttons for this are gray.
    "Dean Saadallah" schrieb im Newsbeitrag
    > it shows up fine.
    > Dean Saadallah
    *Saadallah, Dean
    Re:
    10-10-2003 09:46 PM in reply to: BrianPickles
    OE6 here too: I suspect you might have access to attachments turned off?
    OE6>Tools>Options>Security Tab>Don't allow attachments..... .
    Dean Saadallah
    *Bornhaupt, Thomas
    Re:
    10-11-2003 01:09 AM in reply to: BrianPickles
    my options from OE6 was not correct.
    news:F48CB7D0AC57D774611668D8AC809BCB@in.WebX.maYIadrTaRb...
    > Dean Saadallah
    *Bornhaupt, Thomas
    10-11-2003 01:18 AM in reply to: BrianPickles
    AEV could read this DWF with no problem. But the Header
    information of this file is not correct!
    (DWF V06.00)  has to be (W2D V06.00) look to the Whip6
    SDK Doku.
    VoloView shows 2 errors:
    1) DWF file is newer...
    2) Error regenerating graphic....
    if you change with HexEdit to (W2D V06.00) then the first
    error is gone. But then AEV says: " unknown error"
    Have you an Ascii-Version of this file.
    regards
    Thomas
    I'm
    Active Member
    Re:
    10-12-2003 08:21 PM in reply to: BrianPickles
    Hi all,
    Thomas - Ascii version attached - looks even worse.
    Robin - glad I'm not the only one with image problems.
    Dean - could you see the scanned image in the DWF OK
    are the lines/text 'hollow' when you zoom in
    *Bornhaupt, Thomas
    Re:
    10-12-2003 09:54 PM in reply to: BrianPickles
    Hi Brian,
    the file is still zip-encoded. It is not a pure ASCII File. To
    have a closer look to the file i need a unziped file.
    Thomas
    PS: tis is not a problem of ASCII or Unicode.
    Hi
    all,
    you zoom in
