DWF
DWF6 - display of .tif images
24 REPLIES 24
Message 1 of 25
1404 Views, 24 Replies
I'm using ADT3.3 +Raster design as a tool to archive old scanned drawings - have a problem displaying DWF6 in AEV.
Image format is binary .tif, I had no problems using old format .DWF - Now image displays lines & text as 'hollow' instead of solid black. see attached dwf file. anyone have any ideas ?
24 REPLIES 24
Message 2 of 25
There was no attachment.
If it is an Ascii DWF then you can send it to
href="mailto:Thomas@Bornhaupt.de">Thomas@Bornhaupt.de
regards
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I'm
Message 3 of 25
The attachment is there: are you accessing this through browser? I use OE,
it shows up fine.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 4 of 25
You aren't alone, I have this with tiffs in dwfs also.
Robin Capper
Email; robin.capper.design@xtra.co.nz or robin.capper@thewarehouse.co.nz
"Dean Saadallah" wrote in message
news:542053ABDD8037D2330128610A93847C@in.WebX.maYIadrTaRb...
> it shows up fine.
> Dean Saadallah
Message 5 of 25
Thats silly. I use OE6. I can see an attachment, but i could not extract it.
All buttons for this are gray.
"Dean Saadallah" schrieb im Newsbeitrag
> it shows up fine.
> Dean Saadallah
Message 6 of 25
OE6 here too: I suspect you might have access to attachments turned off?
OE6>Tools>Options>Security Tab>Don't allow attachments..... .
Dean Saadallah
Message 7 of 25
my options from OE6 was not correct.
news:F48CB7D0AC57D774611668D8AC809BCB@in.WebX.maYIadrTaRb...
> Dean Saadallah
Message 8 of 25
AEV could read this DWF with no problem. But the Header
information of this file is not correct!
(DWF V06.00)  has to be (W2D V06.00) look to the Whip6
SDK Doku.
VoloView shows 2 errors:
1) DWF file is newer...
2) Error regenerating graphic....
if you change with HexEdit to (W2D V06.00) then the first
error is gone. But then AEV says: " unknown error"
Have you an Ascii-Version of this file.
regards
Thomas
I'm
Message 9 of 25
Hi all,
Thomas - Ascii version attached - looks even worse.
Robin - glad I'm not the only one with image problems.
Dean - could you see the scanned image in the DWF OK
are the lines/text 'hollow' when you zoom in
Message 10 of 25
Hi Brian,
the file is still zip-encoded. It is not a pure ASCII File. To
have a closer look to the file i need a unziped file.
Thomas
PS: tis is not a problem of ASCII or Unicode.
Hi
all,
you zoom in
Message 11 of 25
Hollow lines and text in AEV, yes.
Dean Saadallah
Message 12 of 25
Hi Guys,
Dean - the raster image in the dwf is not meant to look like that, it is bi-tonal and shows solid b&w in its native autocad display. Any Ideas what's going wrong?
Thomas - sorry, Not sure exactly how to do that.
can you just unzip the DWF using winzip?
thanks for your help
Brian
Message 13 of 25
Without your TIFF, and/or original DWG file, no idea.
Dean Saadallah
Message 14 of 25
OK Dean,
You asked for it - your challenge....
recreate a .DWF6 that actually looks like the .DWG
(zip attached)
P.S.& Please tell me how.
good luck
Brian
Message 15 of 25
Not a DWF6, seems to be the problem.
Dean Saadallah
Message 16 of 25
Hi Brian,
if you save/Create the DWF-File there must be an option
Compressed/Zip or not.
Thomas
Hi
Guys,
what's going wrong?
DWF using winzip?
Brian
Message 17 of 25
Dwf 6 files themselves must begin with (DWF
V06.00).
Internal whip vector streams should begin with (W2D
V06.00).
SDK Doku.
regards
Thomas
I'm
ideas ?
Message 18 of 25
Hi again guys,
Dean - did you use the 'publish' command to create a multipage DWF which uses the new DWF6eplot.pc3 file?
as this is the method I'm having trouble with.
(downloaded from Autodesk so I can test out the multi-page format before we upgrade to 2004)
Thomas - Only get two choices, compressed binary or zipped ASCII encoded 2D stream, The third option 'uncompressed binary' is greyed out.
P.S. Are you a programmer or draughtsman?
anyone else have any ideas - could it be the dwfplot7.hdi driver that needs updating? do you know the latest version number?
I've stayed too late my dinners got cold
Brian
(determined to resolve this, have you had any luck Robin?)
Message 19 of 25
DWF6ePLOT gives me exactly what you are posting. It also fails with the
DWFWriter app.
Good old DWF-ePLOT in 2002 seems to be trouble free, and is what I posted.
No setting changes to either PC3 file would give me what the other did.
Dean Saadallah
Message 20 of 25
Dean, hope they get it right soon - been holding off upgrade for months now, probs after probs. we have 7000+ old drawings (some scanned) to put on a mobile data system.
which need to be clearly viewable by emergency services.
im gone
dinner very cold now
Brian
”Boost
”Tips
”Services
