DWF
DWF and Hatching
2 REPLIES 2
320 Views, 2 Replies
DWF and Hatching
I have a map that I'm working on that contains a theme with the swamp hatch pattern. On one page when I plot to DWF I get the full layout but the hatching never shows up. On another page, from essentially the same layout, I get a DWF that appears to be missing information or is layered incorrectly. Depending on the hatch pattern that I choose, the problem can go away but I never actually get any hatching. In all cases the thumbnail displays correctly (I don't know if this means that the info is the dwf or not).
I have moved the map/dwg to another machine and still get the same behaviour so I don't think it is a graphics card issue.
Is there anything I can do to get a complete DWF with the correct hatch pattern?
Thanks.
2 REPLIES 2
What graphic board does show the discrepancy?
Thank you.
wrote in message news:5904347@discussion.autodesk.com...
not).
pattern?
Thanks.
Both graphics cards result in the same DWF the same problem. One is an nvidia FX-1000 and the other is an ATI Fire GL.
The differentiator seems to be what type of hatching I choose. With 'shape fill 12' I get a full dwf although with no detectable hatching with either swamp or grass I seem to get a partial dwf.
In AutoCad layout view the hatches do appear correctly.
I am using AutoCAD MAP 3D 2008 with SP1 installed. I am plotting with the standard DWF6 ePlot and using acad.ctb. Neither have been modified.
I have attached the swamp pattern dwf. I could not attach both as it/they are too large.
”Boost
”Tips
”Services
