DWF
Distinguished Contributor
buttons129
Message 1 of 8 (78 Views)
DWF adds `.plt' to filename
78 Views, 7 Replies
10-09-2003 10:07 PM
can anyone explain why a dwf filename gets .plt added to it prior to creating a dwf, example, filename was 1234.dwg and the filename after creating a DWF is 1234.plt.dwf (xp and Autocad 2004)
*Saadallah, Dean
Message 2 of 8 (78 Views)
Re: DWF adds `.plt' to filename
10-10-2003 01:01 AM in reply to: buttons129
You manually checked PLOT TO FILE?
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
buttons129
Message 3 of 8 (78 Views)
Re:
10-10-2003 06:11 PM in reply to: buttons129
what other options?. When creating the DWF6 `plotter' after loading the Add a Plotter Wizard, I select `my computer' then select plotter model `Autodesk ePlot (DWF), DWF6 ePlot' then skip the import PC2 file, next page already has the `plot to file' checked! only other option is `Autospool' so how can it be any other?
buttons129
Message 4 of 8 (78 Views)
Re:
10-10-2003 06:17 PM in reply to: buttons129
Dean, forgot to mention that we use Page setups to select the print options based on a template file.
*Saadallah, Dean
Message 5 of 8 (78 Views)
Re:
10-10-2003 09:47 PM in reply to: buttons129
The only time PLT shows up is if you somehow manually select PLOT TO FILE in
the PLOT window: maybe your saved pagesetups have that box checked?
Dean Saadallah
buttons129
Message 6 of 8 (78 Views)
Re:
10-12-2003 05:14 PM in reply to: buttons129
you cant select plot to file when creating a page setup!
*Saadallah, Dean
Message 7 of 8 (78 Views)
Re:
10-12-2003 10:06 PM in reply to: buttons129
No, I meant saved pagesetups as found in the PLOT window... .
Dean Saadallah
buttons129
Message 8 of 8 (78 Views)
Re:
10-13-2003 05:26 PM in reply to: buttons129
Morning Dean, when i select the page set up say
`AO DWF'(comes in from our template) the plot to file is automatically ticked!, if i change the file name the file name becomes say `rawing2-(P).PLT.dwf'
You are not logged in.
Announcements
Need installation help?
Ask the Community
