We love 64-bit. Our applications run on 64-bit. It's not a question of love
for 64-bit. DWF Writer is a weird beast. It's a utility that pretends to be
a printer. It intercepts the print commands and writes what it gets to the
DWF file. DWF Writer is only useful for non-Autodesk applications. Our
applications have their own built-in DWF pipeline, so DWF Writer is a
non-issue for them. We are doing more and more with PDF. Autodesk Design
Review now reads PDF.
wrote in message
news:6234245@discussion.autodesk.com...
Realistically, DWF writer will never compete seriously with PDF if you don't
support 64bit. It is difficult enough to get people to use it (and I try
because I think it is superior/free), but I can't force the issue if it is
not supported. Not including 64bit, considering that Autodesk's flagship
architectural package (Revit) works best on 64bit, is condemning DWF to
always being 2nd rate.
I need to import an Excel file into Revit. Revit has very limited import
capabilities, so I thought that I would DWF print the excel file then
import. Can't install the DWF writer because I have 64bit. I will have to
go to another machine to accomplish this.
