DWF
DWF Wish List
2 REPLIES 2
243 Views, 2 Replies
DWF Wish List
It would be nice if it were possible to combine DWF files similar to the way PDF files can be combined by the "drag and drop" method. We combine published PDF drawings and PDF text documents into one file for bidding purposes. I know its possible to make multiple sheet DWF files, but it would be nice to combine other published DWF files with the drawings.
2 REPLIES 2
You can do this with Autodesk DWF Composer. http://www.autodesk.com/dwfcomposer -- Sriram Gopalakrishnan Autodesk
Hi Tim-- It sounds like what you need is Autodesk DWF Composer. With this product, you can open multiple DWFs side-by-side, and then drag and drop DWF sheets from one to the other. Once you have combined the sheets the way you want them, simply save the new, composite DWF. Here's a link to more information about DWF Composer on the Autodesk Web site: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=4127620. If you're interested, you can download a trial version as well. I hope this helps. Tom Tom VanOstrand Autodesk, Inc. QA Engineer, DWF Viewers Team tom.vanostrand@autodesk.com "TimBalensiefer" wrote in message news:1742116.1093445488745.JavaMail.jive@jiveforum2.autodesk.com... > It would be nice if it were possible to combine DWF files similar to the way PDF files can be combined by the "drag and drop" method. We combine published PDF drawings and PDF text documents into one file for bidding purposes. I know its possible to make multiple sheet DWF files, but it would be nice to combine other published DWF files with the drawings.
”Boost
”Tips
”Services
