DWF
Active Member
timofey.tatarinov
Message 1 of 5 (2,071 Views)
DWF Toolkit - font identification
2071 Views, 4 Replies
04-05-2011 06:22 AM
I am converting w2d file to the custom graphical format. I converted geometry correctly but I had some problem with font conversion. Namely, "my" font size and font size at Design Review are different.
For idenetification font height I do next steps:
1) Get viewport and viewport units transform matrix (WT_Object::Viewport_ID)
currViewportUnitsMatrix = ((WT_Viewport*)pCurrObject)->viewport_units().dwf_to_application_adjoint_transform();
2) Process WT_Object::Text_ID:
a) Get WT_Font through rendition, which got early  WT_Rendition& rendition = _pFile->rendition();
WT_Font wtFont = rendition.font();
b) Convert logical font height value to the application value using viewport and units transform matrix
// for convert value we find distance between 0,0 point and value,0 point - ??? Is another way existing?
PointD point1 = ConvertLogicalPointToSourcePoint(WT_Logical_Point(0, 0), _viewportUnitsMatrix, _viewport);
 PointD point2 = ConvertLogicalPointToSourcePoint(WT_Logical_Point(_value, 0), _viewportUnitsMatrix, _viewport);
 double newValue = sqrt(pow(point1.m_x - point2.m_x, 2.0) + pow(point1.m_y - point2.m_y, 2.0));
PointD ConvertLogicalPointToSourcePoint(const WT_Logical_Point& _point,
 const WT_Matrix& _viewportUnitsMatrix,
 const Viewport& _viewport)
  WT_Point3D point(_point.m_x, _point.m_y);
  WT_Point3D tansformPoint;
  _viewportUnitsMatrix.transform(point, tansformPoint);
  return PointD(tansformPoint.m_x + _viewport.deltaX,
  tansformPoint.m_y + _viewport.deltaY);
After these operations I get a font height which I use in project and it is different from right Design Review height.
What I do wrong?
Another question about font name and family. What I should use for identifying font name WT_Font::font_name() or WT_Font::family()?
Employee
SilviaCao
Message 2 of 5 (2,050 Views)
Re: DWF Toolkit - font identification
04-11-2011 02:24 AM in reply to: timofey.tatarinov
Do you want to convert the text font height to the real text height?  If yes then in step 2) ->b):
  1. Convert the WT_Font to HFONT;
  2. Draw the text with HFONT in a device context;
  3. Get the text height;
  4. Multiply the text height and the viewport scale; then we can get the real text height.
Please let me know if you have any further questions.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Active Member
timofey.tatarinov
Message 3 of 5 (2,046 Views)
04-11-2011 06:27 AM in reply to: timofey.tatarinov
Your solution is working! I converted the text font height to the real text height.
Thank you for quick reply.
Timofey Tatarinov
Active Member
timofey.tatarinov
Message 4 of 5 (2,044 Views)
04-11-2011 06:50 AM in reply to: SilviaCao
Silvia Cao,
Our application is working on Windows now. But we want to support our system on linux too. And we have a question:
What can we do for converting of the text font height to the real text height on linux?
Employee
SilviaCao
Message 5 of 5 (2,037 Views)
04-11-2011 07:18 PM in reply to: timofey.tatarinov
The font supported in DWF is TrueType; so we need to install the graphics library which can support the TrueType (like Simple DirectMedia Layer); and then process the text like in Windows.
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
You are not logged in.
Ask the Community
