DWF
Member
kkcnkc
Message 1 of 2 (230 Views)
Can not access ADViewer object in JavaScript
230 Views, 1 Replies
11-17-2011 01:00 AM
Hi All,
I am try use your below code in JavaScript but it does't work.
I am refer Autodesk Design Review 2012 API Reference
I am try to Execute code in "Embedding a DWF File in a Web Page" this topic.
but not able to
execute, some thing is missing and i am not able to find what is missing or
what is wrong. Help
me.
Please try to execute my Code.
[code]
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
<script language="javascript" type="text/javascript">
function getElements()
          var ADViewer = document.getElementById("ADViewer"); // 2nd Way
        alert(ADViewer);
        var ECompViewer = ADViewer.ECompositeViewer;     // 1st Way
        alert(ECompViewer);
        var Sections = ECompViewer.Sections;
        var secList = document.getElementById("SectionList");
        for (iSection = 1;(iSection <= Sections.Count); iSection++)
                var Section = Sections(iSection); //Set the section to a
separate object
                alert(Section.Title);
                secList.innerHTML += Section.Title + "<BR>";
</script>
</head>
<body>
<input type="text" size="20" /><br />
<input type="text" size="20" /><br /><br />
<input id="abc" type="button" onClick="getElements()" value="How many input
elements?" />
        <object id="ADViewer" type="application/x-Autodesk-DWF" width="400"
height="400"
                        data="application/DWF085825-1-zobell_residence.dwf">
                <param name="Src"
value="http://50.57.86.168:8181/cat/DwfFile/DWF085825-1-zobell_residence.dwf
        </object>
</body>
</html>
[/code]
In my PC this code execute in Google Crome but below issue.
Please try this code to execute.
In my Code there are 3 alert boxes.
  In 1 alert box shows [object HTMLObjectElement]
  In 2 alert box shows undefined
  3 rd alert box not executed.
Another thing is that this JavaScript code only run in Google Crome. not in
IE 8.0 or FireFox  3.6.12
When i am using [ classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" ]
this code it will not
execute in Google Crome not IE 8.0 not in FireFox 3.6.12 also not loaded DWF
Viewer in browser.
My PC Configuration is :
      Windows 7 Ultimate
      1 GB RAM
      64-bit OS
      Autodesk Design Review Browser Add-on for NPAPI browser v 1.2
      Autodesk Design Review 2012 Software v 12.0.0.98 installed in PC.
Reply as early as possible.
Thank you.
Employee
herbert.he
Message 2 of 2 (223 Views)
Re: Can not access ADViewer object in JavaScript
11-17-2011 06:17 PM in reply to: kkcnkc
Thank you for your question.
To insure your script works in both IE and Chrome/Firefox, please refer to this port for solution.
    http://forums.autodesk.com/t5/Autodesk-Design-Revi​ew/DWF-won-t-load-in-Firefox-nor-Chrome-but-will-...
Please let me know if I can be of any further assistance.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
You are not logged in.
Ask the Community
