DWF
janderssen
Message 1 of 3 (237 Views)
Background color
237 Views, 2 Replies
01-09-2014 04:05 PM
Hi All,
What is the correct way to work out the background color of a dwf file, I already support WT_Background and WT_Contrast_Color, but I still have a file that loads with a black background in design review, and I cannot work out why it is doing so. (or how it decides to show the background black)
Thank you in advance for your help.
Cheers
Jason
**Master
dmfrazier
Message 2 of 3 (173 Views)
Re: Background color
02-18-2014 11:25 AM in reply to: janderssen
Not sure if you're still looking for info on this, but I was able to determine that it's possible to select the background color in the DWF (DWFPlot11.hdi) driver properties:
The default is white.
xSmiffyx
Message 3 of 3 (159 Views)
02-28-2014 08:02 AM in reply to: janderssen
Hi
If you right click on the dwf file when open in design review and select options. Refer to AU Forum 1 image.
You should then see (AU forum 2) under general tab - view settings canvas colour you can set te back ground for your dwf files. :smileyhappy:
"Please Mark "accepted as solution" if this solved your question and give KUDOS"
You are not logged in.
Announcements
Need installation help?
Ask the Community
