DWF
Autodesk Design Review 2013 : Cannot open large file
2 REPLIES 2
786 Views, 2 Replies
Hi All,
I have some problem about ADR 2013, it cannot open large file amount 50 MB.
I was export from "Product Design Suite 2013 - Autodesk Inventor Professional 2013"
While I'm tried to open, it remain and crashing down.
Do you have some recommend?
System: Windows 7 + SP 1 (64 bits)
Processor: Intel Xeon E5410 @2.33 GHz
Memory: 8 GB
passath
2 REPLIES 2
pendean
So if it was much smaller and from the same source it works?
Yes, mostly it can be open with maximum size not more 20 MB.
Windows Application Logs
The program DesignReview.exe version 13.0.0.82 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: 8bfc
Start Time: 01ce82038ec5ed2f
Termination Time: 324
Application Path: C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\DesignReview.exe
Report Id: 433b4d53-edf7-11e2-8db9-0023ae822311
”Boost
”Tips
”Services
