DWF
Adding Sheet Properties to DWF File
1 REPLY 1
1109 Views, 1 Reply
Is it possible to add/set sheet properties to DWF files? then How can I add sheet properties using DWF toolkit?
Tags (2)
1 REPLY 1
In Revit, filled up property fields first before export. In AutoCAD using Sheet Set, Information fields should be filled up prior to publishing to DWF. I don't know your platform, but the above are easier for multiple sheet properties inclusion. Goodluck!
”Boost
”Tips
”Services
