• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DWF
    Active Contributor
    Adding Hyperlink to an object in the existing DWF
    682 Views, 4 Replies
    01-03-2012 07:04 PM
    Hi all, Happy new year !!!
    I like to know the possibility of adding Hyperlink to object in the existing DWF file. then save as new DWF.
    Would it be possible?
    Please use plain text.
    Member
    herbert_he
    Re: Adding Hyperlink to an object in the existing DWF
    01-08-2012 10:12 PM in reply to: intratech
    Thank you for your question.
    Autodesk Design Review does not support adding hyperlink to the existing DWF/x file.
    Please let me know if I can be of any further assistance.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Active Contributor
    01-08-2012 11:20 PM in reply to: intratech
    Thank you for the info. then I'll have to look at the DWF tool kit. Thanks.
    Member
    12-21-2012 08:06 AM in reply to: herbert_he
    I'm sorry to hear that AutoDesk doesn't support this.  Adding hyperlinks before the DWF is created is much too early in the markup process.  Links to RFI's, equipment data sheets, and other communications are generated later as the construction groups become involved and they don't have access to the original design drawings to add these kinds of links.
    This will push us to abandon DWFs and go with PDFs for our construction review and data management.
    Please let us know when AutoDesk catches up.
    Mike Johnson
    CAD Support
    IM Flash Technologies
    New Member
    Re: Adding Hyperlink to an object in the existing DWF or Revit Project
    05-28-2013 09:49 AM in reply to: intratech
    Although I can create hyperlinks to Views,
    We would have many uses for being able to somehow(work arounds accepted) select a room tag or alternate item within a room layout plan and be "hyperlinked to an appropriate SHEET LAYOUT (eg room data sheets, Specification sheets etc.)
    This would be beneficial in both Revit and DWF
    Anyone know of anyway to get this right.
