"a_salembier" <Hi
href="mailto:salembier@metafoor.nl">salembier@metafoor.nl> wrote in
message
href="news:f177fac.-1@WebX.maYIadrTaRb">news:f177fac.-1@WebX.maYIadrTaRb...
Everybody,
can someone tell me how to create DWF with multiple sheets possibilities. I
heard about someone it was possible with Autocad R2004, but i'm using Autodesk
Map5 en 6. Is there also a way to do that with these versions of autocad? So
not...is there another way to create it easily.
Thanks a lot for any
information.
Arnaud.
"Jeffrey Klug (Autodesk)" <jeffrey dot klug at autodesk dot com>
wrote in message
href="news:77A566604251E06E87254CE977264672@in.WebX.maYIadrTaRb">news:77A566604251E06E87254CE9772......
I'm not sure if it works with Map 5, but you
could give the DWF Creator a shot, might be worth the try:
href="http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=2497593">http://usa.autodesk.com...
Good luck. Let us know if it works for
you.
"a_salembier" <Hi
message
Everybody,
I heard about someone it was possible with Autocad R2004, but i'm using
Autodesk Map5 en 6. Is there also a way to do that with these versions of
autocad? So not...is there another way to create it easily.
Thanks a lot
for any information.
Arnaud.
