Yet more info. (Are you tired of me yet?)
Using the Publish command (with TuTu's DWF6 util) vs. the Plot command's DWF
makes a difference too. Publish's file is ok (no clipping or text smearing),
while the Plot's file is still bad.
R. Robert Bell, MCSE
www.AcadX.com
"R. Robert Bell" wrote in message
news:38CEFF8532E8F7E80769E094519D879A@in.WebX.maYIadrTaRb...
| Well, the older format was generated by someone out-of-house. That might
not
| be the culprit.
| The titleblock is an XRef (attached, not overlaid). With our normal
printer
| margins, the titleblock falls within the margins. Under a dwf, it does
*not*
| (again, where is that determined?). If Fit justified text falls *outside*
| the "new" margin, it "smears" to the left, generating the bad DWF files I
| posted in cf.
| www.AcadX.com
| news:62F3512CBC29CE6126565238EFE1451E@in.WebX.maYIadrTaRb...
| | More info. This problem does not occur in the older dwf format.
| hiss>
| | www.AcadX.com
| | news:EDE51C5BD29AF97C052767E2A92733AC@in.WebX.maYIadrTaRb...
| | | It appears to be related to text that is Fit justified.
| | | Also, what determines the page margins? They do not match the page
| margins
| | | of our plotters (nor did I expect them too, but I do not see any place
| to
| | | specify margins either).
| | | www.AcadX.com
| | | news:DC3CCD18FD31EA8DD6B18FF058D30C63@in.WebX.maYIadrTaRb...
| | | | Looks like the new format has trouble with some types of text
| | (especially
| | | in
| | | | the titleblock XRef of the sample drawing).
| | | | I have posted to customer files (same thread) a zip with two sample
| dwf
| | | | files, and the associated files used to create them. Any ideas as to
| | what
| | | is
| | | | going on?
| | | | www.AcadX.com
