You are correct. I often group object data with hyperlinks because from a
rendering point of view they both populate the selection data structures.
The viewer is spending a lot of time processing all the selectable
hyperlinks. But you are also correct; the incremental loading in the viewer
is defiantly an area for improvement.
When I wrote the renderer/loader used by Freewheel, I removed the overhead
of things like objects, hyperlinks, incremental loading and other things.
The viewer can't simply remove these things, but needs to improve them.
Ben
wrote in message news:5268007@discussion.autodesk.com...
I do not think this has anything to with object data: there isn't any in
this DWF. When I extract the W2D file and view it separately it is just as
slow.
The extreme delay seems to be caused by the preview-while-rendering. When I
open the file and minimize the DWF viewer while it is loading the file, I
can see in the taskmanager it is finished loading in about 15 seconds.
Restoring the window takes some 5 more seconds and I am up and viewing in 20
seconds, 10 times faster than normal opening.
