DWF Viewer (Read Only)
Printing Multiple sets
5 REPLIES 5
tdodd
355 Views, 5 Replies
Does any one know how to make the DWF viewer print multiple page DWF multiple times? When I enter number of copies (10 for example), it prints the first page 10 times, the second page 10 times, and so on. Then I have to collate by hand. Is there a way to make it print all sheets first then start over and print all sheets again as many times as needed so I can pull a set of the plotter and staple instead of collate?
Todd
5 REPLIES 5
in reply to: tdodd
It sounds like you have collate checked in the print dialog. "tdodd" wrote in message news:20862178.1107362068028.JavaMail.jive@jiveforum2.autodesk.com... > Does any one know how to make the DWF viewer print multiple page DWF multiple times? When I enter number of copies (10 for example), it prints the first page 10 times, the second page 10 times, and so on. Then I have to collate by hand. Is there a way to make it print all sheets first then start over and print all sheets again as many times as needed so I can pull a set of the plotter and staple instead of collate? > > Thanks > Todd
tdodd
in reply to: tdodd
I have tried it both ways, with collate checked on and with collate unchecked. I get the same result either way.
-Todd
in reply to: tdodd
Can you look at the driver settings. I wonder if the driver is doing this. Ben "tdodd" wrote in message news:26723187.1107533639762.JavaMail.jive@jiveforum1.autodesk.com... > I have tried it both ways, with collate checked on and with collate unchecked. I get the same result either way. > > -Todd
tdodd
in reply to: tdodd
Ben,
How do i go about looking at the driver settings, I have had to do this before?
Thanks for your help!!
-Todd
in reply to: tdodd
When you click the "Properties" button in the print dialog the print driver UI is launched. If you want to permanently change the print driver setting, right click on the printer and select properties from the Windows Start menu. Ben "tdodd" wrote in message news:12850376.1107875977323.JavaMail.jive@jiveforum2.autodesk.com... > Ben, > How do i go about looking at the driver settings, I have had to do this before? > > Thanks for your help!! > -Todd
