Autodesk is aware of the problem. It is corrected in the beta that is going
on now. You can go to http://myfeedback.com, register, and request
participation in the Amazon beta.
wrote in message news:5152792@discussion.autodesk.com...
With the patch, I got an IE script error. The details:
Line: 222
Char: 13
Error: Object doesn't support this property or method
Code: 0
URL: file://C:\Program Files\Autodesk\Autodesk DWF Viewer\EPlot\index.html
Go to the html file, found "NavPane.ViewsCtrl.SetViewer(iAdViewer);" on this
line. It seems ViewsCtrl is the object. Believe it has not been activated in
this point and causes this error.
The error happens even I use the viewer desktop app to open a dwf file.
Does autodesk aware of this? When do we have a fix?
Thanks.
