There might be some sort of HTML Meta tag that does minimizing or something
like that, but nothing in a viewer URL as far as I know.
"Jimmy B" wrote in message
news:D34D42568A66A67381E26A3F9B7BACFC@in.WebX.maYIadrTaRb...
> Jeffrey,
> You got me on the right track. Now it works. The users are so exited to
have
> such an easy interface to add printers.
> I made a HTML file as follow that I linked to from the DWF.
> Is it possible to have the new window hidden or minimized?
> Best Regards, Jimmy B
> CAD and Database Developer Manager at www.pharmadule-emtunga.com
> Take a look at the trial version of SmartPurger (now for AutoCAD 2004) or
> download some freeware at www.jtbworld.com
> More on AutoCAD 2004;
> www.jtbworld.com/autocad2004.htm
> www.jtbworld.com/autocad2004tips.htm
> "Jeffrey Klug (Autodesk)" skrev i
> meddelandet news:3AB87CBB4068B4BF81AC0A224F459DCC@in.WebX.maYIadrTaRb...
> > I believe the only thing you can do is to wrap your VBS in a CAB file
> (which
> > runs the VBS), and the CAB file in an HTML file, then link to the HTML.
> > news:EFE785D9F6E4B7906FBB269E157B3E42@in.WebX.maYIadrTaRb...
> > > I've made a DWF of our office with symbols for the printers. The
> hyperlink
> > > is to a vbs file that will install that printer.
> > > The thing I would like to avoid is the dialog box for "file download"
> that
> > > warns you and force you to select Open to have the script run.
> > > Is it somehow possible to do this without the dialog box?
> > > I've tried to changed the security setting and trusted sites and so on
> but
> > > could not get it to work.
> > > The DWF and the vbs files will be placed on an intranet.
> > > Would it be easier if it is was exe file that would be executed?
> > > vbs file below:
> > > on error resume next
> > > Set WshNetwork = CreateObject("WScript.Network")
> > > WshNetwork.AddWindowsPrinterConnection "\\EMTNT12\EMTANX03"
> > > Any ideas are welcome.
> or
