Thanks John, I can use this also.
It sure would be nice to have a GOOD API help file. Why keep secrets? By
getting programmers to use the DWF Viewer, it will get distributed far and
wide as part of software applications.
"John Schmier (ADSK)" wrote in
message news:5043850@discussion.autodesk.com...
This may help you, I have a sample written for JavaScript that should give
you enough information to figure out where the API is and how to call it
(sorry, I don't have a quick sample for .NET)
To remove the Save button from the toolbar
var PageViewer = ADViewer.Viewer;
PageViewer.ShowCommand("SAVE", FALSE);
To remove the save as command from the context menu (right mouse menu)
ADViewer.ContextMenu.RemoveItem("Root.SaveAs", -1);
wrote in message news:5042023@discussion.autodesk.com...
I am working at the project using .NET
with DWF Interop components.
I want to know how disable Save As button's functionality?
