Thank you for your positive comments in the other thread about Autodesk
leaving the link for the Autodesk DWF Viewer around. People are free to
continue to download Autodesk DWF Viewer 7.0 on an as-is basis. Similarly,
there are customers who are still using DWF Viewer 6.0 and 6.5 for API
reasons. But here's where it gets interesting. There are no plans to make
any updates to DWF Viewer 7.0. If the problem you are describing is being
encountered with Autodesk DWF Viewer 7.0, you may wish to try Autodesk
Design Review 2008 to see if it is indeed corrected. Many defect corrections
went into Autodesk Design Review 2008. On the other hand, if you are using
Autodesk Design Review 2008 already and are encountering this problem,
please supply a test file so I can log a defect.
wrote in message news:5568825@discussion.autodesk.com...
When trying to open a DWF file through IE7 (double click on file) a runtime
error occurs in IE7. When the same file is opened by going through DWF
Viewer file opens fine. This runtime error only occurs with files created
using DWF 6 and in IE7 only.
Any ideas?.
