DWF Viewer (Read Only)
DWF File format setting up
1 REPLY 1
praneeta24
1478 Views, 1 Reply
This is Praneeta and I have one query regarding DWF File format setting.
Currently our application creates DWF files of American standard format ANSI 8.5*11. we want to convert the DWF file format to ISO A3 format.
Manually we can do this by setting up ISO format using DWF writer for 2d or 3d.
Can it be feasible, that we can use DWF writer properties which can set the DWF file format through any code or so and it will create DWF files of ISO format?
Please help me....
Thank you in advance.
Praneeta
1 REPLY 1
dickyshu
in reply to: praneeta24
Hi Praneeta,
Thank you for posting.
I am afraid there is no API control of the DWF Writer Properties – and adding that at this time is not in scope, so you may not be able to do that from code.
Hope it answers your question.
-Dicky
Dicky Shu
SQA Engineer
DWF Writer Customer Support
Dicky Shu
SQA Engineer
PSEB-GE-ACRD PSEB
Autodesk, Inc.
