style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"jteselle" <A
href="mailto:jt@jt-architecture.com">jt@jt-architecture.com> wrote in
message
href="news:f16788f.14@WebX.maYIadrTaRb">news:f16788f.14@WebX.maYIadrTaRb...
PDF can do everything that a DWF can, plus some extra things that DWF can't.
Take a look at this page for a comparison of features:
href="http://www.linetype.com/advice/comparison.htm">http://www.linetype.com/advice/comparison.ht...
Also to correct some information stated here: PDFs made from CAD files are
typically vector images, not raster images. So they view and print very
cleanly. I have seen this bit of incorrect information mentioned so frequently
in discussions of PDF and DWF that I have to wonder if some people have ever
seen a PDF of a CAD drawing.
In addition, you can zoom in quite closely with a PDF. The new version of
Adobe Reader (6.0) allows you to set the maximum zoom factor up to 6400%. The
older version (5.1) has a maximum zoom factor of 1600%, which I have never
found insufficient.
DWF files are smaller than PDF in many cases, but this is not a big issue
for most people. I send them to all my clients and have never heard a
complaint.
"jteselle" <I
message
href="news:f16788f.22@WebX.maYIadrTaRb">news:f16788f.22@WebX.maYIadrTaRb...
tried this, and the sizes are about what I have seen in the past -- the
Willhome.DWG file comes out at 169 KB in PDF (using Distiller), and 44 KB in
DWF (using the Optimized for plotting settings) -- both plotted at 11x17 size.
The DWF certainly is smaller, but then the PDF isn't 20 MB either. I doubt
anyone would notice the difference in size unless they are using a very slow
modem.
Although it is probably possible to find certain types of files in which
the PDF is much larger than the DWF, the reverse is also true. I ran a test
plot of a drawing with several imported raster images -- the PDF is 1.4MB, the
DWF is 5.3MB. This is due to the fact that raster images can be compressed in
the PDF, but apparently not in the DWF.
I think that the file size comparision is in almost all cases a non-issue.
What you can do with the file is more important.
"jteselle" <I
message
modem.
