In ADR 2011 if I do a walkthrough using the walk function within the steering wheel my session will freeze after my computer will run out of available memory. In ADR 2010 the problem does not happen on the same exact dwf file. ADR 2010 stays right around ~250M for memory usage. ADR 2011 starts at ~250MB and climbs from there. So if I pan the memory usage will climb to 260MB, then if I zoom it will go to 270MB and so on.
Definately a bit of a bug. The only way that I have found to reset the memory usage is minimize then maximize the application. I don't really want to go to my senior level staff and let them know to monitor task manager and tell them to minimize/maximize ADR when it gets above 500MB...
File specs:
3D dwf from revit 2009, architectural model only
File size is 3.4MB
Computer specs:
Win XPx86 SP3
3Gb RAM
Nvidia NVS 160M
Mark LaBell, Jr.
Technical Leader
SSOE Group
www.linkedin.com/in/marklabelljr
