Constructware Forum
Welcome to Autodesk’s Constructware Forums. Share your knowledge, ask questions, and explore popular Constructware topics.
Contractor RFI
1 REPLY 1
adilkhatri
2103 Views, 1 Reply
Contractor RFI
Is it possible to edit Documnet Template for Contractor RFI Module.
We need to change the Header for that.
1 REPLY 1
james.l.bryant
in reply to: adilkhatri
To verify:
When viewing a Contractor RFI Module document are you specifically needing to use a custom document template or do you need to change what Logo is appearing. If you need a custom document template this is not possible.
The logo that appears by default will be the From Contacts Company Address Logo.
Unfortunately, the Contractor RFI Module is limited in customization. No options are available to customize attributes or viewing options.
James L Bryant
Autodesk Support Team
Contact Autodesk |
