Configurator 360 Forum (Read Only)
Welcome to Autodesk’s Configurator 360 Forums. Share your knowledge, ask questions, and explore popular Configurator 360 topics.
Increase Resolution for Picture Downloads
2 REPLIES 2
DPolsky-VAH
766 Views, 2 Replies
The resolution for a download seems to be set at 96 dpi, anyway to increase this?
Daniel
2 REPLIES 2
Jon.Balgley
in reply to: DPolsky-VAH
Hi Daniel --
Unfortunately, there is no option at this time.
Eventually, we will expose all the options of all the output-types.  One big question in my mind is how/if to expose options to end-users.  I think we can give the admin-user fine-grained control over this, but it will make the interface more complicated.
--Jon
Jon Balgley
DPolsky-VAH
in reply to: Jon.Balgley
Thanks for the quick reply.
I would recommend one global resolution variable for image types at the admin level.  That way the admin interface isn’t cluttered up with settings for all the various image types Configurator provides.  Perhaps just label a field “Image Output Resolution”, default the field to 96, and let the admin user input an integer from 72 to a maximum value (perhaps 300).  Of course you could also make that field a drop down and give a list of resolutions for the admin user to select if you wanted to keep it simple.
